how this oscillator works !?
AlbertHall
Joined Jun 4, 2014
12,652
Applying 3.5V across the base-emitter of a transistor is surely going to blow the transistor. Are you sure there isn't a resistor in there somewhere?
oussama borbon
Joined Apr 21, 2018
9
[QUOTI'm soryAlbertHall, post: 1269000, member: 240904"]Applying 3.5V across the base-emitter of a transistor is surely going to blow the transistor. Are you sure there isn't a resistor in there somewhere?[/QUOTE]
Oh!? i'm sory i did a mestake I forgot to draw the 7 kohm risistor
ian field
Joined Oct 27, 2012
6,536
I think there's some trick oscillator using reverse biased B/E junction - that could be a messed up representation of it.
BR-549
Joined Sep 22, 2013
4,928
What is the transistor? What does an upside down V mean? S G O something 8? What is an inverted V6 uH?
Have you built this? Can you show us on a scope?
oussama borbon
Joined Apr 21, 2018
9
the transistor is npn S9018
the coil is 1.16uH
BR-549
Joined Sep 22, 2013
4,928
The output cap of transistor is about 1.3 pF. With 1.6 uH....that should resonate around 110 MHz. If you are seeing 104 MHz......that is reasonable.
The coil will separate base phase with collector phase ~90. The capacitance between the base and collector must supply the other 90....to get 180 needed for oscillation.
Most old people would call it parasitic. But hey....why not put it to work? Talk about efficiency!
Have you tried acquiring any power from it? It would seem finicky....might make a good sensor.
Just guessing....not a transistor expert.
oussama borbon
Joined Apr 21, 2018
9
[QI OTE="BR-549, post: 1269064, member: 218447"]The output cap of transistor is about 1.3 pF. With 1.6 uH....that should resonate around 110 MHz. If you are seeing 104 MHz......that is reasonable.
Just guessing....not a transistor expert.[/QUOTE]
i built this circuit and i tested it with an FM radio it was oscillate at 104 MHz ... i made this circuit by accident ... that why i don't know how does it oscillate ... i want to know how it oscillate and how I can calculate the frequency i tested it without antenna the range was 10 meters ...
i
oussama borbon
Joined Apr 21, 2018
9
i built this circuit and i tested it with an FM radio it was oscillate at 104 MHz .... I made this circuit by accident that why I don't know how does it oscillate ... I want to know how does it oscillate and how I can calculate the frequency ... I tested it it without antenna the range was 10 meters
ebp
Joined Feb 8, 2018
2,332
"What does an upside down V mean?"
Ein.
That is a common way for Germans to write "1" - which is why "7" typically has a cross stroke to clearly distinguish it. I presume it is not exclusive to Germany. Commas and periods in numbers are used opposite of how they are many places. 1.000 is one thousand. 1,000 is one, to four significant digits.
