Completed Project How much current is drawn by an 18,600 BTU A/C compressor while running at atmospheric pressure?
Rahulk70
Joined Dec 16, 2016
538
I spoke to an HVAC technician friend of mine who has like close to 25 years experience. He told me that since the compressor label says use the phased out R22, all the service guys used the same only because using anything else will mostly require modification else there is risk for damage. No wonder my service for this model was costlier than the newer A/Cs. Also he told me since when I took it out there want any oil in the condenser or evaporator lines then most of the oil is still contained in the compressor itself still which I can hear it splash around while it’s running. He told me that as long as I added two valves to the inlet and discharge things should be okay. And the oil in it should keep the piston lubricated as it swishes around. Maybe I could add a few 5-10ml of the same oil. Also I was told that it’s better to use a compressor oil itself rather than the vacuum oil.
As for the power draw and noise it would be loud only when it’s compressong a pressurized refrigerant which would cause higher current draw too.
MisterBill2
Joined Jan 23, 2018
28,552
When you used as an air compressor did you add any air filter, air filter drier(moisture removal) and also change & add any compressor oil at intervals?
I may have added oil at some time, but never an inlet filter. And the oil added was probably #30 weight motor oil. The second and third compressors came from refrigerators while the first one, that lasted so very long, came from a discarded chest freezer many years earlier. So none of them were treated with much respect.
Of course you would not use vacuum pump oil, because refrigeration compressors need oil compatible with the insulation of the internal motor.
Rahulk70
Joined Dec 16, 2016
538
I saw a guy on youtube say that he used air oil and transmission oil too. This compressor that I have is like 26 years old. So, I think I'll get the mineral compressor oil itself. And then the fact that back in good old days they made things to last for a long time so with little care they should last long.
Yeah, I've decided to give up the idea of using vacuum pump oil after my HVAC buddy said its a bad idea. Getting a little bit of mineral oil isn't that hard he said and you don't have to worry about any damage either.
Rahulk70
Joined Dec 16, 2016
538
Okay guys, a small update. So, I ran the compressor with both inlet and outlet without any restrictions and measured the current draw with a clamp meter. It was 5.5Amps. The current increases for example only when the outlet valve is closed and the pressure is allowed to build up.
MisterBill2
Joined Jan 23, 2018
28,552
You Tube is OK for entertainment but I am not sure how much you should trust it for technical assistance. Just some advice based on what I have seen.
Rahulk70
Joined Dec 16, 2016
538
Thanks for the concern. But I gave up that idea of using other oils other than the specific one for the compressor. I've some polyester oil but didn't use it. So, as my HVAC technician buddy told me I just used the mineral oil that he gave me to use in this compressor. I don't use the compressor regularly so only very little oil is lost while using it.
MisterBill2
Joined Jan 23, 2018
28,552
I was commenting that not all of the information on YouTube is always 100%. Your tech friend is a far better source of wisdom.
Rahulk70
Joined Dec 16, 2016
538
Of course. Absolutely agree with that! People do lot of crazy stuff. xD. Yep, he has helped me with a lot of stuff. He has like 20-25 years experience in HVAC and electrical stuff.
