How much current can this circuit output?
Ian0
Joined Aug 7, 2020
13,255
That circuit does have a bit of a problem - at the moment of power up, the capacitor is immediately charged to the battery voltage at as much current as the wiring can sustain, which may well be rather too much for that weedy little BA159 1Amp diode.
And in answer to your questions:
maximum current =1 Amp - it's limited by the diode
ISL78268 - No - it's a buck regulator so it steps the voltage down not up.
I also wonder why one would want to charge the super capacitor to its absolute maximum voltage, and not simply let it charge to the battery voltage.
Papabravo
Joined Feb 24, 2006
22,111
I think you know the answer to that question.
Papabravo
Joined Feb 24, 2006
22,111
You would of course need to do this on a printed circuit board. Doing this on a breadboard of any description might not work out so well.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
1. If changed BA159 as a large diode say SB550, can it increase the current to 5A?
2. when mentioned the ISL78268, I can use a step down circuit, can I use its large current?
3. How do you think to charge the supercapacitor [SC] to certain Voltage, can the SC keep that voltage stable?
In fact, the base capacitor allowable voltage is only 2.7V.
DickCappels
Joined Aug 21, 2008
10,661
I think what Papabravo was trying to communicate is now that you are up into multiple amps a plastic plug-in breadboard might not handle the current without an unacceptable voltage drop or damage to the breadboard itself.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
I will test the circuit in a small current first?
Papabravo
Joined Feb 24, 2006
22,111
Thanks.
You don't understand what I am trying to say. Testing at small currents may lead you to draw unwarranted conclusions, especially when it comes to running at higher currents and higher frequencies. Unfortunately you CANNOT slow walk this process. You have to cut printed circuit boards and learn by doing. There are special things you do in PCB layout and fabrication for SMPS's with high current and high frequency. You cannot learn what they are or appreciate them by experimenting with lower currents and frequencies. Doing it the right way might take 3-4 board turns. Doing it the wrong way might take you 10.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
OK, I'll do on pcb, which one better left or right?
Alec_t
Joined Sep 17, 2013
15,156
Even 5A would be pushing it if you intend using perf-board. You can connect strip-board tracks in parallel to handle multi-amp currents, but there are limits.
Track inductance and inter-track capacitance also become significant at high switching frequencies.
Ian0
Joined Aug 7, 2020
13,255
Taking this capacitor as an example
https://uk.rs-online.com/web/p/electric-double-layer-capacitors/1845030/
it has a DCR of 30mΩ.
Connect six in series to a 12V battery (I'm assuming a SLI battery with the capacity to deliver >1000A), through a diode and the current will be 67A, and a 70F capacitor will take some considerable time to charge - over a second at that current.
You're going to need rather a lot of strips of perfboard in parallel to deal with that.
Don't forget that the circuit has no way of limiting the current until the capacitor voltage exceeds the battery voltage.
LowQCab
Joined Nov 6, 2012
5,102
The whole premise of this project is not very practical.
If You charge the Capacitor(s) to ~16V, you then have to add an
extremely high-Current Voltage-Regulator to match the Voltage of the Battery.
You then have Charging-Circuit losses, plus, Regulating-losses,
adding up to a lot of wasted Power.
Batteries and Capacitors operate on completely different principles.
The Voltage will be more consistent, for a longer period of time, with 2-Batteries.
A second Battery, would not only be much cheaper,
but would also provide more than double your current run-time, without all the complexity.
( the run-time will more than double because the discharge-rate on the Batteries will be cut in half,
and therefore, there will be fewer internal losses in each Battery )
Your Boost-Converter will need a Inductor with at least ~14-Gauge-Wire, (12ga. would be better),
have you done the calculations for building a 25-Amp Choke ?
It's not as easy as it looks.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
'strip-board track' yes, it is what I was planing to use.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
It's good idea to connect them in series and charging in a higher voltage, even actually used in parallel. About the current control before capacitor voltage exceeds the battery voltage, I have had a question asked here:
https://forum.allaboutcircuits.com/...rrent-adjustable-circuit.179495/#post-1639761
I'll try the circuit suggested?
LAOADAM
Joined Nov 21, 2018
956
Thanks.
I'll use two-battery unit.
I don't have a Inductor yet, where can buy it?
