how measure watt of lighting LED
mcgyvr
Joined Oct 15, 2009
5,394
How do you know the Vf and how do you know the lumen output? Did you measure them?
Without a datasheet/part number/spec it would either be trial/error (aka run it at some current and measure the temps) or possibly measuring the physical size of the LED and comparing to others..
Post a picture of this LED..
In general "wattage" really isn't a number you need to know.. Vf and max current rating are the real numbers to use.. With that you can calculate the "wattage".. But IMO "wattage" really isn't a number you need to know to use an LED at all..
sendbad
Joined Jan 8, 2015
43
vf and lm Printed in Base of it
djsfantasi
Joined Apr 11, 2010
9,237
And why did it stop working? Was the battery dead? Was it a new battery when you started your test? Or without a resistor, was the LED dead?
djsfantasi
Joined Apr 11, 2010
9,237
Note I asked about the resistor because connecting an LED without one is a sure way to destroy the LED. There are some very specific exceptions, but generally an LED requires a current limiting resistor.
Did you make your measurements at the points illustrated in the picture below?
Is this how you got your measurements of 3.7 VDC and 4.8 mA?
Ignore the two AA batteries... I just used them to represent your battery. (What are you using for a battery?)
@BobTPH, where are you getting on the order of 1 W? If we are to trust the OP figures (!), your original calculation seems right to me.
There is so much conflicting /extraneous information here and little hard facts. We need to know
  • What is the LED
  • What is its forward voltage
  • What is its rated current
  • What is the power source
  • How are the measurements being taken.
  • Forgot about the lumens
BobTPH
Joined Jun 5, 2013
11,618
The 1W comes from that fact the state of the lighting LEDs produce about 60 to 100 lm / watt. If the LED produces 70 lm, it is somewhere on the order of 1W.
Bob
djsfantasi
Joined Apr 11, 2010
9,237
Hence my conclusion that there is conflicting information. From the data given, there are two widely divergent, yet plausible, answers to how much current is being used...
