assuming your supply can give infinite current support, how many mA can a standard header pin on a pcb handle?
100,200,300, 400?
Thanks in advance
100,200,300, 400?
Thanks in advance
100,200,300, 400?
Thanks in advance
typo PCB ridiculous smart phones change everything to whatever they want now daysWhat's a pub (besides a tavern in Britain)?
This is my favorite "all about circuits" reply!The datasheet will tell you.
yes sir I'm talking about the standard header pins found on like a mother board used with like a JST connector.If you are referring to .025" square pins, the answer is in amps rather than milliamps.
Typical ungrateful TS....... if it's not in the manufacturer's datasheet, unless you run your own tests, where else will you find it?This is my favorite "all about circuits" reply!
Typical answer
"read the datahsheet"
Don't you think if i had found the answer in a data sheet i would not be asking?
Another candidate for the ignore list. I don't have any time left for whiners.Typical ungrateful TS....... if it's not in the manufacturer's datasheet, unless you run your own tests, where else will you find it?
No problem finding the current rating here:
http://uk.rs-online.com/web/p/pcb-headers/2779742/?origin=PSF_435704|acc
How difficult was that?
Think about it, checking the datasheet is the only way to find the answer, we don't have the actual pin in front of us.o look its the other genius!
you guys must be twins!
You both have the answer regularly!
"check the data sheet"
Why don't you both just retire or go find something else to do. Telling someone to check the data sheet is never a good answer
And I suggest you take your crappy attitude and go somewhere else with your questions.o look its the other genius!
Well "genius" it obviously is if that is where they will find the answer.Telling someone to check the data sheet is never a good answer
