What is the basic components or part that make radio frequency into short range or long range?
Range has very little to do with components and everything to do with frequency. Generally speaking the higher the frequency, the shorter the range. There is also a diurnal variation in range depending on the position of the sun and the conditions in the upper atmosphere. There is also the 11 year sunspot cycle and our present position in that cycle. It is possible to adjust range slightly by increasing or decreasing the radiated power of the output. This is the last thing you do after everything else has been tried.What is the basic components or part that make radio frequency into short range or long range?
Ok its the frenquency ...how far in radius is the 4G (2.6 Ghz) can transmit (i meant generally)? Can it be like 50 Km? or at least 20 KmRange has very little to do with components and everything to do with frequency. Generally speaking the higher the frequency, the shorter the range. There is also a diurnal variation in range depending on the position of the sun and the conditions in the upper atmosphere. There is also the 11 year sunspot cycle and our present position in that cycle. It is possible to adjust range slightly by increasing or decreasing the radiated power of the output. This is the last thing you do after everything else has been tried.
At that frequency the transmission distance is basically line of sight. Another thing that will have an effect on the distance is atmospheric moisture, since water molecules absorb and scatter microwave frequencies.Ok its the frenquency ...how far in radius is the 4G (2.6 Ghz) can transmit (i meant generally)? Can it be like 50 Km? or at least 20 Km
It depends on the transmitted power, gain and radiation pattern of the transmitter antenna, gain and radiation pattern of the receiving antenna.Ok its the frenquency ...how far in radius is the 4G (2.6 Ghz) can transmit (i meant generally)? Can it be like 50 Km? or at least 20 Km
It's weird. But the maximum distance at 2G, 3G.....is not due to transmit power(5W) or sensitivity of reception(-109dBm).........Ok its the frenquency ...how far in radius is the 4G (2.6 Ghz) can transmit (i meant generally)? Can it be like 50 Km? or at least 20 Km
True, the signal can be transmitted much longer distances (low earth orbit intercepts of cell signals) but the 4G TDMA technology networking is limited by the speed of light and the need to have round-trip timed slots for users.It's weird. But the maximum distance is not due to transmit power or sensitivity of reception........here.
It is given by the time advance variable.
by Jeff Child
