how is current flowing from low potential to high potential?
Amr Moneer
Joined Jan 25, 2018
10
this is a solved problem from the textbook i'm using. the results are: v1 = 4.8v, v2 = 2.4v and v3 = -2.4v
the 2ix dependent current source is directed from v3 to ground although v3 is at a lower potential than ground. how is this possible? shouldn't current flow from high potential to low potential?
problem and solution are in attachments.
WBahn
Joined Mar 31, 2012
33,326
It's a dependent SOURCE.
Draw a simple circuit with a battery and a resistor. Is the current through the battery going from the negative terminal to the positive terminal?
A source has the ability to convert some other form of energy into electrical energy by forcing current to flow from a low potential to a high potential.
It's like saying that rocks have to always fall from a higher elevation (gravitational potential) to a lower gravitational potential. Not true. Put the rocks in an elevator and use some other source of energy to move them upwards against gravity.
Amr Moneer
Joined Jan 25, 2018
10
does that happen only with dependent sources?
