How does the led driver figure it out..?
ronsimpson
Joined Oct 7, 2019
4,794
A good LED driver should not blow smoke if the diodes (LEDs) get shorted out. Most of my drivers continued to push the rated current into a short. Some dropped back to hiccup mode, where they drove rated current for a 1mS then gave up for a while them tried again.
Jon Chandler
Joined Jun 12, 2008
1,635
The power supply is a constant current LED supply. The forward voltage of white LEDs is about 3.5 volts, so at a current of 300mA, about 1 watt we be supplied to an LED bead. The voltage range of 25 – 90 volts covers series strings from 7 to 27 LEDs. For any number of LEDs in series from 7 to 27, the current through each will be 300mA, with the voltage varying as required to maintain 300mA in the circuit.
Wrapping your head around a constant current supply can be tough. Say you have a 10mA constant current supply. The supply will do everything it can to put 10mA through a circuit. If you put a 100 ohm resistor across the output, the supply will make the output voltage 1 volt to maintain 10mA in the circuit. If you put 500 ohm resistor across the output, the supply will put out 5 volts to force 10mA through the circuit. A dead short will cause the voltage to drop to nearly zero, to maintain the 10mA current flow.
So what happens if the circuit is open? The constant current supply will try its best to keep 10mA flowing by raising its output voltage as high as it can but of course it can't raise it any higher than the voltage it has to work with.
