How does a MOS capacitor work?
HunterDX77M
Joined Sep 28, 2011
104
I'm starting on a design where capacitors and diodes must be made from transistors. I know diodes can be made from connecting the gate to the drain (like in a current mirror), but what about a MOS capacitor?
From searching around, I've found that shorting the drain and source together and using them as one terminal, along with the gate as the other makes a capacitor. Am I correct in assuming the oxide capacitance/area (C_ox) multiplied by the area (width and length of the device) determines its capacitance? What other factors are involved?
Also nagging me: how does current flow through the device if the gate oxide is an insulator?
38,952
All capacitors have an insulator between their plates. That's how capacitors are made.
The MOS capacitor is no different.
That's why capacitors block DC and only pass AC.
dl324
Joined Mar 30, 2015
18,524
If you're talking about MOSFETs, you don't get a diode by connecting drain to gate. There's a parasitic diode between the source and drain.
Shorting the BE or CB junctions on a BJT would give you a diode, but the diodes are there whether or not one junction is shorted.
For a MOSFET, gate capacitance will be given in the datasheet. Generally, it's
\( \small C = \frac{\epsilon A}{d} \)
But most datasheets won't give you the gate area, dielectric constant, or gate oxide thickness.
This might help: http://www.electronics-tutorials.ws/capacitor/cap_1.html
shortbus
Joined Sep 30, 2009
10,049
Won't the "gate capacitor" also be very limited in both farads and voltage? A very ineffective capacitor if it would work at all.
WBahn
Joined Mar 31, 2012
33,356
I sure used a LOT of diode-connected MOSFETs in the ASICs I've designed.
https://en.wikipedia.org/wiki/Diode-connected_transistor
http://web.eecs.utk.edu/~jhollema/classes/ece336/lectures/slides06.pdf
http://web.mit.edu/6.012/www/SP07-L25.pdf
It's diode characteristic is most definitely NOT due to the parasitic diodes -- you almost never want to forward bias those.
And a big reason for that is that gate capacitance is HIGHLY non-linear with voltage -- so that equation does you almost no good for a FET capacitor.
WBahn
Joined Mar 31, 2012
33,356
For a discrete transistor this is probably true since you are comparing it to discrete capacitors. But on an IC the FET capacitors almost always provide WAY more capacitance per unit area than any other structure can provide precisely because they use thin oxide instead of field oxide.
