How does a 555 IC timer works and how can I implement it by having a 30s timer
Nani Kore
Joined Sep 23, 2017
21
So basically my idea is that I have 10 LEDs and assuming each two is equivalent to 1 minute. The idea is that all of those LEDs would be on, and when I press probably a tactile push button the timer counts down. If 30 seconds passes by then the first LED would turn off. Can anyone tip me on how I would be putting 30s on each led and how they would be counting down. All I know is I think I'll be using a D Flip Flop. What I have right now are: 555 IC, Speaker/Buzzer, LEDs, resistors-capacitors, tactile push button, breadboard, and jumper wires.
ro169
Joined Oct 10, 2014
62
Are you trying to create 5 minute timer which notifies you visually in 30 second intervals?
You could use your 555 timer to trigger counters which will keep track of the time elapsed
Colin55
Joined Aug 27, 2015
519
You can use 10 555's as they cost only 5 cents
Or you can use a LED bar graph chip in bar mode or you can use a micro.
Or you can use a staircase of transistors. It just depends how accurate you want the display and how simple you want the circuit.
Nani Kore
Joined Sep 23, 2017
21
Yes, I'm trying to create a 5 minute timer which reminds me every 30s when each LEDs are turned off, so from the start ( 0:00 ) All LEDs are turned on. Then when 30s passes by the first LED turns off
ro169
Joined Oct 10, 2014
62
okay if you'd like to avoid programming and reduce costs you could go with a simple digital circuit.
There are a number of ways you could achieve this depending on how long you set the period on the 555 timer to.
For example:
You could set the 555 timer in astable mode to generate a 1 second pulse, so every second that passes, the timer will output a pulse. Then use BCD counters to keep track of the amount of pulses. Use 2 cascaded counters like the CD4510 (1 for seconds and for for tens of seconds).
Then you can use combination logic gates to detect when the tens of seconds counter has reached 3. The gates could then reset the tens of seconds counter as well as well as turn off one of the LEDs.
OR you could increase/decrease the period on the timer and use more/less counters.
Personally I'd prefer using a single AVR microcontroller with simple C code. Would get the job done much quicker!
Nani Kore
Joined Sep 23, 2017
21
Hahaha I have microcontrollers but since i have buzzers/speakers and 555 ICs Ive been wanting to try them out. Thanks for the help I'll ask if theres any!
dl324
Joined Mar 30, 2015
18,479
Would this do the trick?
No. CD4017 only has one output active at a time.
I'm with @absf.
Chain some shift registers to get 10 bits, use LOW outputs to drive the LEDs, and use a CMOS 555 to shift in a HIGH that will turn them off one by one at 30 second intervals.
dl324
Joined Mar 30, 2015
18,479
You could try something like this:
Notes:
  1. A CMOS timer should be used.
  2. Timer period is 0.7*(R12+2R13)C1 seconds. Using the nominal values for R13 and C1, setting R2 R12 to 28.6k would give 30 seconds. But cap tolerance could be -20 to +80%.
  3. Switch bounce won't affect operation.
  4. The current in the LEDs must be low enough that the logic level of the shift register outputs isn't affected. If higher current is required, some other driver such as CD4050, darlington/transistor arrays, or discrete transistors, could be used.
  5. The CD4069 inverter could be replaced with a discrete inverter.
EDIT: Corrected typo on R12 in note #2.
Nani Kore
Joined Sep 23, 2017
21
Notes:
  2. Timer period is 0.7*(R12+2R13)C1 seconds. Using the nominal values for R13 and C1, setting R2 to 28.6k would give 30 seconds. But cap tolerance could be -20 to +80%.
Thank you so much for this info! I will try to experiment with this now after I buy the materials!
dl324
Joined Mar 30, 2015
18,479
There are some issues with the circuit. I'll let you decide how problematic they are and how much complexity you're willing to add to overcome them.
Bernard
Joined Aug 7, 2008
5,784
I'm using a circuit almost identical to Post # 10 except for 20 LEDs & SN74LS164N shift registers Instead of loading 1s am loading flickering LED.
Nani Kore
Joined Sep 23, 2017
21
The value of the IC is what exactly? I'm having a hard time finding them. I'm trying to tell the shop owner that its a D flipflop and with the 4015N value
dl324
Joined Mar 30, 2015
18,479
The shift register part number is CD4015N; the N suffix indicates dual in line package.
I breadboarded the circuit and found that NE555 can do 30 second intervals, so you can use a bipolar part if you can't get a CMOS veraion.
absf
Joined Dec 29, 2010
1,968
You can get them from eBay 10 pieces for USD3.01 including postage.
Here's how I did it with 2x 74HC595....
Not sure if the SH_CP and ST_CP are connected correctly but it does work. Add in the 555 and reset button as in Dennis's circuit....
Allen
Nani Kore
Joined Sep 23, 2017
21
Allen
This worked beautifully! Thank you! I just saw just now but it happened that I have the 74HC595s!
dl324
Joined Mar 30, 2015
18,479
Have you noticed that when you first apply power, the first interval is longer than the others? Have you noticed any problems when the circuit is reset?
Nani Kore
Joined Sep 23, 2017
21
Yes definitely noticed that so I adjusted some parts to to equally distribute the intervals. I've got a fully working 5 minute timer. Although the tactile button messes it all up. It stops the timer but pressing it again wont turn it back on. I have to disable then able the power to make it work again
