How do you come up with the I-V characteristics
WBahn
Joined Mar 31, 2012
33,321
This is Homework Help -- we don't just provide answers.
Show your best attempt to do it and explain where you are getting stuck and we can help you figure out what the issue is and work through it.
Papabravo
Joined Feb 24, 2006
22,115
There are at least two ways to define a function so that you can produce a plot:
  1. Derive an expression so you can plot the expression
  2. Make a table of points that you can plot on a set of axes; then connect the points with a smooth curve.
poposeed
Joined Jul 7, 2018
8
I tried coming up with an equation for plotting the graphs , I am not sure if I even did that right. To me that just look like y=mx+c equation ???
Papabravo
Joined Feb 24, 2006
22,115
When the diode is on it has a voltage drop of \({V_{F}}\). which should be in the range of 0.6 to 0.7 volts depending on the current. In particular you cannot model it as a short circuit. Good start on deriving the expressions.
38,920
It's stated on the schematic to be an ideal diode, so I assume that means the forward drop is zero.
MrAl
Joined Jun 17, 2014
13,859
Yes the diode drop is zero but you can always account for that later by just calling it Vd for now.
