how do I access "it" outside the function?
arduinolego611
Joined Jan 23, 2022
75
how could I access "it" outside the function?
Code:
void iD()
        vector<string> airports = {"ATL", "BOS", "DEN", "DFW", "EWR", "IAH", "JFK", "LAS", "LAX", "LGA", "MCO", "ORD"};
        unsigned long n = airports.size();
        for (i = 0; i < n; i++)
            map <string, int> airportKeys;
            airportKeys [airports[i]] = i;
            map<string, int>::iterator it = airportKeys.begin();
            if (it != airportKeys.end())
                cout << it-> first << " " << it-> second;
I will also ask - how could I access "nbr" outside the function?
Code:
#include <iostream>
#include <map>
#include <vector>
#include <list>
using namespace std;
class Graph
    int V;
    list<int> *l;
public:
    Graph (int V)
        this->V = V;
        l = new list<int>[V];
    void addEdge(int x, int y)
        l[x].push_back(y);
        l[y].push_back(x);
    void printList()
        for (int i = 0; i < V; i++)
            cout << "Vertex " << i << "->";
            for (int nbr:l [i])
                cout << nbr << ",";
            cout << endl;
int main()
    Graph g(13);
    g.addEdge(1, 2);
    g.addEdge(2, 4);
    g.addEdge(2, 8);
    g.addEdge(3, 1);
    g.addEdge(4, 3);
    g.addEdge(4, 6);
    g.addEdge(5, 3);
    g.addEdge(6, 7);
    g.addEdge(7, 6);
    g.addEdge(8, 9);
    g.addEdge(9, 10);
    g.addEdge(10, 8);
    g.addEdge(10, 11);
    g.printList ();
    return 0;
(still consider myself a noob and appreciate people being gentle, lol )
BobTPH
Joined Jun 5, 2013
11,573
but "it" is both a string and an int, how do I declare that?
or should I say it first is a string and it second is an int
It is neither. It is an iterator for a map object that maps strings to integers.
Read about maps and iterators for maps in the C++ library documentation.
maps
arduinolego611
Joined Jan 23, 2022
75
yes that's right, I got confused for a second... so how do I get around the error message "use of undeclared identifier" if I try to print the map values and the adjacency table from the other block of code together like here in line 5 -
Code:
void printList()
            cout <<  it-> first << " " << it-> second << i << "->";        //HERE
            for (int nbr:l [i])
                cout << nbr << ",";
            cout << endl;
all I want is for the each airport name to be on the same line as the corresponding data from the adjacency table
do I need to create a variable and store those map values in it or something?
