how carrier be suspressed in DSB modulation?
fansaiti
Joined Apr 1, 2022
6
in books, AM always described as y(t) = [A + m(t)].c(t), where c(t) refers to carrier wave, m(t) is baseband/modulating signal.
A sometimes be explained as the amplitude of m(t). Because of the existance of 'A', the carrier part be kept together with upper and lower side band.
However, when we decribe DSB, 'A' be removed from equation, as a result, carrier be suspressed and only upper and lower side band remains.
I am not clear, how does 'A' be represented in hardware(real circuits)? How to remove 'A' in circuits?
Papabravo
Joined Feb 24, 2006
22,113
Careful design of the mixer can eliminate the carrier and the modulating signal, leaving only the two sidebands. Alternatively, the carrier can be removed with a filter that suppresses the carrier. The basic operation of the mixer involves the multiplication of sinusoids which gives rise to the sidebands.
38,932
An analog multiplier with two inputs consisting of the carrier and the modulating signal will generate a DSB signal with no carrier.
(If the modulating signal is zero, then you are multiplying zero times the carrier signal which is zero at the output).
fansaiti
Joined Apr 1, 2022
6
Great and thanks a lot^_^ In other words, the 'A' is anyway exist inside a baseband/modulating signal, but if we wanna a DSB signal, a filter circuit should be introduced to kill the carrier part ? Actually, some books said, 'A' is a DC signal which is added before multiplication, as result AM with carrier produced. When you want to produce a DSB, just remove this DC signal inputting in your circuit. It seems that, theoretically, there are two methods to produce a DSB signal, 1. produce a AM first then suspress the carrier by filter; 2. multiply the baseband/modulating signal to carrier directly, without adding DC('A') signal.
which method is applied in real ampitude modulate circuits ?
fansaiti
Joined Apr 1, 2022
6
Thanks. How do you think modulating signal ? [A+m(t)] or just m(t) ? I prefer to think just m(t) as modulating signal, while A is a DC be added artifically when designing circuit.
38,932
Mr zapper, could you please explain 'If the modulating signal is zero' ?
You are multiplying two signals together.
If one is zero volts than the output is also zero.
So if the modulating signal is zero volts, then there is no signal, and thus no carrier present at the output.
That's how the carrier is suppressed.
But note that, at the receiver, the carrier must be recreated to properly demodulate the signal.
Sometimes a small value of carrier signal (pilot carrier) is transmitted to make it easier for the receiver generate the carrier for the demodulation.
Also, since the two sidebands have duplicate (and redundant) information, one of the sidebands can be eliminated (by filtering or other techniques) to generate the more commonly used single-sideband signal.
That reduces the required RF bandwidth and allows concentration of all the transmitted power into one sideband.
fansaiti
Joined Apr 1, 2022
6
Mr zapper, could you please explain ' If the modulating signal is zero ' ?
Take this equation as example: y(t) = [A + m(t)].c(t), where c(t) refers to carrier wave, m(t) is baseband/modulating signal,
A as the amplitude of m(t). The modulating signal includes A and m(t), let A=0, we obtain a DSB(carrier suspressed), while let A>0, we obtain a AM with carrier and double side band. Do you agree? If it is, do you know, how should A be introduced into real circuit? By adding a DC over m(t) signal ?
There are the traditional analog filter methods and newer digital methods of SSB/DSB-SC modulation.
https://eng.libretexts.org/Bookshelves/Electrical_Engineering/Electronics/Microwave_and_RF_Design_I_-_Radio_Systems_(Steer)/03:_Transmitters_and_Receivers/3.07:_Case_Study-_SDR_Transmitter
An SDR transmitter combines DSB-SC modulation having a relatively low intermediate frequency carrier with a broadband analog SSB-SC modulation to produce a DSB-SC RF signal. There are many possible implementations. This case study presents system simulations of an SDR transmitter with specific parameters. First a DSB-SC quadrature modulator is studied with sinusoidal in-phase and quadrature baseband signals and then a SSB-SC modulator is examined. This is followed by the study of a direct analog modulation of a digital signal. The final study corresponds to a typical SDR transmitter with DSP-based intermediate frequency DSB-SC modulation followed by SSB-SC analog modulation producing a DSB-SC modulated RF signal.
Suppression of the carrier is a property of the multiplicative mixer but some types of modulators, e.g. amplitude modulators, have the carrier in the RF output signal and hence the suppressed-carrier distinction being used with quadrature modulation.
