How can this circuit work as a toggle on-off switch?
38,773
adding a diode and small capacitor to each stage would guarantee that the activated stage would stay set after the common reset signal had returned high.
That's a good idea.
It's also called a radio push-button circuit, and that modification should make it reliable (I didn't realize that was what the TS wanted).
Here's the LTspice simulation:
I added a resistor and a capacitor.
I selected the opposite latch output for the signal, since a high output for the selected PB is more commonly wanted.
Of course the circuit can be expanded indefinitely with added stages.
Jony130
Joined Feb 17, 2009
5,600
It seems that I got more luck than scioto because the circuit on the breadboard works without any problems except for the random behavior at startup. I use CD4011B for Ti and HCF4093 from St. In both cases the circuit works.
switch bail, a mechanical bar that releases any buttons not pressed (think old mechanical car radio station buttons).
Thank for the name in English. And can you post the LTspice file?
And again thanks for the Help.
38,773
After some more though on the problem I decided that the capacitors could be eliminated, with the input capacitance being used for that purpose.
To that end, I increased the value of the resistor to get a few microseconds delay with the small input capacitance, which should be sufficient to insure the latch stays in the desired state.
I also added a power-on reset transistor, M1, so that all outputs are zero at power up.
LTspice .asc file attached.
Edit: I reduced the value of R2 to help insure that the reset signal goes high before the set signal.
sghioto
Joined Dec 31, 2017
8,750
Respectfully disagree. Are we talking about the circuit in post #25? If so, I doubled checked my wiring and stand behind my results in post #31.
SG
Jony130
Joined Feb 17, 2009
5,600
The only difference is in that I have two pull-up resistors for pin 6 and pin 13.
And I do not guarantee that the circuit in question will work with every single NAND gate IC in the world.
sghioto
Joined Dec 31, 2017
8,750
That and you used 10K pull-ups. OK, I changed the pull-ups to 10K and added the additional 10K ( that was not on the schematic:) ) and now it works. Go figure.:D
SG
EDIT: Of course replacing the two 10Ks with a 4.7K works as well.
Jony130
Joined Feb 17, 2009
5,600
Guess what happened when I increase the pull-ups resistors to 100kΩ? The circuit stops working LOL.
What is more funny is that I used 10kΩ originally by accident because I got a bunch of them laying around on the bench. So, I've got lucky after all.
