how can this circuit be adjusted to amplifier smoothly and correctly, hfe is 165 ?
Alec_t
Joined Sep 17, 2013
15,171
To avoid the clipping, increase the 8k resistor value and decrease the input signal amplitude.
You can probably ignore the hfe value, since no two transistors will have the same value.
hobbyist
Joined Aug 10, 2008
892
Alright lets take the time to work this through.
You are having the negative peaks clipping, which means is the transistor is biased on the higher end of the load line.
For the transistor to work as a linear amplifier you want to have the transistor biased close to the mid point of the load line.
Do you need to draw up a load line, absolutely Not. Do you need to know hfe of a transistor, heck No.
Here is a tried and true procedure that works for a quick analysis to see where your at on the biasing.
Use these equations.
12V x 2.6K / (2.6K + 8K) = 2.94V (this is the voltage at the base)
Now subtract (0.65V) from that to give a approx. value of emitter voltage. (2.94V - 0.65V) =2.29V at the emitter.
Now take (2.29V / 1K ohms) =2.29mA. this is the aprox. value of emitter current.
take (2.29mA x 3.9K ohms)=8.94V, this is the voltage drop across the collector resistor.
Now add the voltage drop calculated across the collector resistor to the voltage drop across the emitter resistor
(2.29V + 8.94V)=11.23V This is the voltage across both resistors in the transistor branch, Now to see what voltage is across the transistor, subtract the value above from the supply, (12V - 11.23V)=0.765V across the transistor.
The transistor is biased on heavely.
For the circuit to work as an amplifier it is good practice to have around half the supply voltage across the collector resistor.
In your biasing scheme. you have close to around 9V dropped across that resistor.
That leaves less than 3V left for the transistor to operate under, if saturation voltage is counted for.
Here is a way to fix it.
assume 6V to be dropped across the collector resistor. Now solve for collector current, (6V / 3.9K ohms)=1.5mA.
Now keeping your original values of collector resistor, and emitter resistor, take (1.5mA x 1K ohms)= 1.53V for the emitter voltage.
Now add Vbe of 0.65V to that and (1.53V + 0.65V)~=2.19V for the base voltage.
Now if you take the collector current (1.5mA) and divide that by ten (1.5mA / 10)=150uA.
This is the voltage divider current that would be high enough to keep the base voltage stable under differing values of transistor hfe's.
Now take base voltage (2.19V) divided by the divider current (150uA).
(2.19V / 150uA)= 14.6K. Here a 14.7K could be used.
Lastly take the supply voltage and subtract the base voltage, and the remaining voltage will be the voltage drop needed across the top base resistor. (12V - 2.19V)=9.81V.
And divide the divider current into this voltage (9.81V / 150uA)=65.4K, using LTspice a 64.9K can be used.
Now to set the gain of a stage, you divide the emitter resistance into the collector resistance, (Av = RC / RE), for DC gain.
In our circuit we will have around (3.9K / 1K)~= 4.
That means we have alot of neg. feedback, and a very stable circuit, however this is an "ac" amp, not a dc amp, so in order to get the AC gain up high, you use a cap. as you did, in your scheme.
So for our circuit, lets put a cap in there, but lets calculate a value for it so as to not over drive the stage.
Use the equation (Xc = (1 / (6.28 x frq. x C)) rearrange to get C (1 / (6.28 x freq. x "XC").
Now choose a value for Xc which is the capacitor reactance at freq. 1Khz.
Lets try for a gain of around 60 so the emitter resistance would need to be 60 times less than 3.9K ohms at the collector.
(3.9K / 60)= 65 ohms. This value is very small compared to 1K ohms in the emitter lead that's a good thing.
Now thequation would be (1 / 6.28 x 1K x 65)=2.4uF for value of C
So we could START out with a 2uF cap, and see if theres any distortion, if not than we can slowly increase the value to get more gain. I ended up using a 3uF value to get this gain of around 60, as seen in the pic.
100mV. PK-PK input and around 6.27V PK-PK output. around Av=62.
This should help you get a understanding of how to bias your transistor stages for linear operation to avoid clipping, with maximum gain.
Audioguru
Joined Dec 20, 2007
11,248
Instead of measuring the AC output, connect the scope to see the DC output at the collector of the transistor then you will see why the transistor is biased wrong.
