How can quantum theory explain the Existence?
BR-549
Joined Sep 22, 2013
4,928
Physics should be the study of what matter and light are and how they interact with each other. From this we will know the correct questions to ask on the biggest mysteries of wonder. For almost 100 years science(physics) has failed in this regard. QM or QE is bad ju-ju. A point can not be a particle. A point can only have location and nothing else. Yet particles have mass, charge, spin and a magnetic moment. All in a point or some mysterious vapor that has all the INHERENT properties without cause.....it's just there....nature.......BAD JU-JU. That’s what they tell us matter is. GRAVITY... all of space and time change when matter moves...............ha ha ha. I can not believe that educated people can believe such things. Such arrogance. About 2 years ago I found a group of physicists who have determined the physical structure of the 4 fundamental particles. From this the real structure of atoms can be modeled. These models show the physical cause of spin, charge, mass, magnetic moment, and radio decay. These models also predicted more nuclides and spectrum which has been verified. From these models the force of inertia has been derived. Also from these structures, a 4th order term was found.......to be gravity. It is not the same as inertia. From the real structure of stuff......the universal force law has been derived. This is the greatest accomplishment of science so far. These are the true physicists of our time. Now...for the good news. Space is constant and rock solid. A meter is a meter no matter where is is or at any scale or time. Speed of light......c....limit......only on light. Because it takes a finite time to exchange fields. If your not changing fields....you can go faster. Gravity.....it is attractive....but it has a twist(a real twist...it’s chiral) to it. This is were Bodes law comes from. Almost all red shift comes from it. By the way.....the center of the universe isn’t too far from the Milky Way. Gravity is not constant.....it never has been. The CBR is not leftovers from the big bang. It is radiation from decaying of gravity. Mass....there is no such thing. Matter is not mass. All fundamental particles have the structure of a very very thin stripe on a hula hoop. The stripe is composed of charge. If the stripe twist to the left.....it’s a negative charged particle. To the right...positive. An electron hula hoop radius is about 3E-13 m. The hoop is just the surface that the charge can be located.....it’s not part of the structure. The stripe or charge radius is 3E-110 m. The charge is evenly spread and rotates at the speed of light. That’s about 20 amps of current and that causes a magnetic field thru the hoop. The magnetic field is what keeps the charge bound in the stripe. The charge is bound, but not the electric and magnetic fields. An almost spherical static electric and static magnetic field(at right angles to each other) is around a free state electron. The charge has one twist in the ground state. These field lines have tensile strength and the stripe is elastic. When the field lines are distorted from another particle....the stripe and fields react to un-distort the lines. That’s inertia. It’s an electric and magnetic feedback. Inertia and apparent mass. Now a proton has a hoop radius of 5E-15 m. A much smaller hoop.....many twist to the stripe and much higher angular momentum(and mass). The current in a proton is 30000 to 50000 amps and higher. Now we’re talking magnetism! This is what’s called the nuclear strong force in modern physics.
Quantum Theory......does it matter?
Wendy
Joined Mar 24, 2008
23,797
You logic fails in one important regard. We are using these admittedly incomplete theories to make some very usable gadgets. When a theory works but falls short it means it needs tweaked.
Yes, Quantum Theory does matter, and works.
socratus
Joined Mar 26, 2012
267
Now...for the good news . . . . .
. . . in my opinion . . . . . the Zero Vacuum: T=0K + QED
will give the answers to all these biggest questions of Nature.
