How can I test a BGA (Ball array) chip, in circuit?
camerart
Joined Feb 25, 2013
3,853
I'm making PCBs for AK8963C chips, shown here: https://forum.allaboutcircuits.com/...ectronic-errors-oshonsoft.187539/post-1741319
When I've soldered them onto the PCB, obviously I can't check the balls as they are under the chip, so how are these type of chips tested, after soldering?
So far I've used a meter and continuity mode and diode mode. With diode mode, I connect the +V lead to GND, and check the tracks in turn, if there is no result, I either swap the leads around, or switch to continuity mode. Usually, I get some reading, which isn't open or short. Today I made 9x PCBs 5x good 4x bad.
EDITED.
Cheers, Camerart.
ronsimpson
Joined Oct 7, 2019
4,797
so how are these type of chips tested?
We test then with JTAG. JTAG
Most large ICs have a JTAG port so you can test the pins. In test mode the normal functions are shutdown and the pins are made to be I/O for testing. You can set pin 52 to out and set to 1 or 0.
On a mother board all the ICs are set to test mode. You can set a pin on the CPU to 1 and read back from a memory pin if the CPU really did go to 1.
If there is only one large IC the another way is to toggle each pin one at a time and measure the amount of signal you can see on an antenna. A disconnected pin produces very little noise while a long connection makes a large amount of noise.
There are many other ways to test but this is a start.
camerart
Joined Feb 25, 2013
3,853
Hi R,
I suppose that the JTAG PIN will be TST1 here:
For my level of skills, my method of 'suck it and see' may be best for me. I'm getting better that 50% pass rate, which may be upped, by re-floating the chips again. I only need a few more to cover the near future.
Thanks.
C
ErnieM
Joined Apr 24, 2011
8,415
Where I work we check the solder balls by looking at them.
It sure helps to have a real time industrial X ray machine for this.
camerart
Joined Feb 25, 2013
3,853
Hi E,
An x ray machine would be handy.
I changed the title, by adding 'in circuit', meaning is it possible to test by resistance or similar?
So far, if all of the PINs show a high resistance (High K Ohm or M Ohm) then they ususally work, but as mentioned I'm getting >50%.
C
