How can I replicate these big trace areas from an old PCB using kiCad?
Barrakkuda
Joined Mar 29, 2018
5
Hello everybody, I'm trying to replicate an old PCB from a vintage audio receiver. How can I make the big trace areas as you can see in the screenshot? The screenshot shows a grayed out image with the old traces behind the new ones I'm making.
AnalogKid
Joined Aug 1, 2013
12,268
Polygons, or copper pours. PADS has both. The difference is that a copper pour can be assigned to a net, such as GND, and the software maintains connectivity even when parts and vias are moved around.
ak
MaxHeadRoom
Joined Jul 18, 2013
30,808
The greyed out areas are filled zones, (Add a Filled zone.) you can select any route or plane (power or ground),
Select the route & Draw the area you want to create a plane for.
Ian0
Joined Aug 7, 2020
13,273
Filled zones.
Draw a rectangle around the area where the zones are required. Tell it which net it connects to and it will do the rest for you.
