How can i make this audio preamp circuit work?
Iwt
Joined Oct 29, 2022
11
Why did you change the value of R12 from the value in the original circuit ? With the original value that stage would provide some gain. With the value that you used it would attenuate the signal.
Les.
That was a mistake on my part, nothing intentional!
LesJones
Joined Jan 8, 2017
4,544
Hi Eric, I am asking the TS. The high value of the emitter resistor in the output stage of the circuit in post #1 was the first thing I noticed that would cause the signal to be attenuated. The 2.2K value in the circuit in the link from post #17 make more sense as it would give a voltage gain of about 4.
Les.
WBahn
Joined Mar 31, 2012
33,290
Would love to be able to design a circuit all by myself. Unfortunately I don't have the knowledge for that.
Yet the course you are taking would appear to assume that you should be able to do so by this point. You might need to retake the course. If you do, you would be in a position of knowing what you need to learn the second time around so that you are better prepared to focus and pay attention to the right things. The alternative is to limp through via excessive help from others and end up in a course you are even less prepared to succeed in.
