how can i improve accuracy of 12057 RTC
Pranav Tonape
Joined May 29, 2021
hi,
in my project i am using isl12057 RTC for a date and time,the VT-200-F crystal provide 32.768KHz frequency. my circuit have stray capacitance of 7.5+pf, and parallel capacitance for crystal is 5 pf, Now in this circuit condition i got an increment delay of 3 sec after every 24 hours. we can't change the board design also
pleases guide me how can i fix this problem and delay reduces to zero. and also reduce the stray capacitance of the board.
Papabravo
Joined Feb 24, 2006
22,115
hi,
The simple answer is that you are unlikely to get to zero unless you build your own Cesium clock. As has been pointed out operating in a temperature stable environment will be a big help.
ErnieM
Joined Apr 24, 2011
8,415
Just get out your eraser, bite the bullet and admit your design is 20 years out of date.
Looking on Digikey for single quantities the Renesas part is $2.60, then you have to add your crystal and other comps.
For an additional $1.42 ($4.02 each) you get a MAX31328, a complete timing chip with an internal temperature compensated crystal good for a "Timekeeping Accuracy ±3.5ppm(±0.302 seconds/day) from -40°C to +85°C" right out of the box with no twiddling or fiddling with trimming anything.
