How can I convert TTL pulse train to current?
Ankit Garg
Joined Dec 9, 2016
My input is TTL pulse having amplitude +5V, freq from 500KHz to 5Hz and duty cycle 50%.
The output should follow this relationship
I = C * Vc * freq
Where,
Vc= +5V (Pulse Amp)
freq= pulse frequency
C is the capacitor (to be connected in series with the input signal)
The circuit should consists of diodes, capacitors and resistors only..
Thanks in advance!
WBahn
Joined Mar 31, 2012
33,126
What is I? The average current? The instantaneous current? The rms current? The current at noon in the River Thames?
Where is this current to be measured?
What attempt(s) have you make so far?
Ankit Garg
Joined Dec 9, 2016
I is the average current and the circuit shall output current proportional to the input freq.
WBahn
Joined Mar 31, 2012
33,126
So is the current supposed to be DC? AC at the same frequency as the input signal?
Where is the current that is being controlled? In the capacitor? In some resistive load?
What attempt(s) have you made so far? Remember, this is YOUR homework problem (and it is pretty obviously a homework problem of some sort). So far we have seen nothing that indicates you are interested in anything more than getting someone else to do your work for you.
dannyf
Joined Sep 13, 2015
2,197
use a rc network to turn the pulses into charges on the rising and falling edge.
use a diode to gate the charges to either rising or falling edge.
use another diode to direct the charges onto a capacitor.
parallel the capacitor with a large resistor to turn the voltage on the capacitor into a current source.
done.
