Need to convert continuous dc signal to a single pulse
imani9009
Joined Nov 8, 2013
56
CamScanner 09-11-2022 09.05.jpgHI,
I have created a timer with 4060 and 4017 ic. To turn a relay for specific time. I want a trigger signal for this relay at pin# 12 of the 4060 ic. I have a dc supply of 12 volt. I want to convert this continous dc to a single pulse. Here is the schematic. If 555 or simple components like transistor are used for this purpose it will be easy for me.
imani9009
Joined Nov 8, 2013
56
So we don't make assumptions:
1. How long do you want the relay energized?
2. What is the part number of the relay?
I do not want a relay with 555 timer, I have shared a circuit of 4060 timer, 4060 circuit stops when it has counted its time, the relay is attached with 4060 circuitry. It only starts again when a pulse is applied at its pin#12, the supply of 555 time should reset the timer only. The supply of 555 will come from output of this circuit Battery Voltage Monitor with LM339
sghioto
Joined Dec 31, 2017
8,751
The circuit triggers a pulse, but it is generating a approx 2.3 volt pulse and is not triggering the reset of 4060 pin#12.
What is the supply voltage feeding the 555?
BTW the link to that LM339 Battery Monitor is not correct it only shows the 4060 circuit.
imani9009
Joined Nov 8, 2013
56
Actually for testing purpose i was using 9 volt battery, but i was also missing something, connecting the grounds of 2 circuits. Well thanks for the great circuit.
