How can I connect these two circuits using a D flip-flop?
pinkoryx
Joined Dec 11, 2017
47
Don't worry, I'm not going to just give you the answer.
I'll try to teach you to figure out what's going on so you'll be able to troubleshoot other problems.
What is it that you don't understand about D flip flops?
I'm sure you will you're literally the best thank you thank you thank you X1,000,000 for your time, effort and patience!!! You have no idea how grateful I am. I have not added any "to" device, I will and when I do i'll post a screenshot, thanks again
dl324
Joined Mar 30, 2015
18,446
Now I added a 'To' device and now everything looks like this:
Now you need to add "To" devices to the counter outputs of both counters and the clock for the first counter. And remove the short between the first stage counter reset to the second stage clock.
You also need to give them unique names.
pinkoryx
Joined Dec 11, 2017
47
Do I add 'To' devices to the 4 outputs of both counters? Or just to one output connection on both?
pinkoryx
Joined Dec 11, 2017
47
Here's what I understand:
on the 0-9 counter, when it resets, R = 0. When I want the 0-5 counter to hold, the values of L,C, and R should be 0, right? So it makes sense to connect a NOT gate to the 0-9 counter (to invert 1 to 0) and connect the output (0) to L and C outputs on the 0-5 counter
dl324
Joined Mar 30, 2015
18,446
Is reset LOW active or HIGH active?
Explain the function of those inputs to me.
Connect a NOT gate to what? What would that do? We're trying to troubleshoot the erratic count problem.
Explain the function of L and C; BTW, they're not outputs.
pinkoryx
Joined Dec 11, 2017
47
Low active means the pin holds the value zero, right? (And high active means the pin equals 1 - that's what I understand at least)
Since R is activated when its value is 1, I would say it is HIGH active
L - load - loads input (i was just about to ask where from since my registers don't have any input connections to load from)
R - reset - starts over again (ex. when it reaches 9, it starts over from 0 when R = 1)
When C and U are 1, the register will count up.
When C is low (zero) the register will hold the present state. It also says when R, L, C are 0 it will hold.
dl324
Joined Mar 30, 2015
18,446
LOW active means the input responds to a LOW logic level, or falling edge for edge triggered inputs.
Why did you say it was LOW active in post #50?
That's my point. You're not using the load functionality, so why do you want to change it?
Why do you want to change any of these inputs? Isn't the first counter working properly with them as connected?
pinkoryx
Joined Dec 11, 2017
47
Thank you for the info!
I dont remember saying that
Yeah you're right!!!
dl324
Joined Mar 30, 2015
18,446
it doesnt specify which one in write up they sent us so i'm not sure
You should do it the way you were being taught before this test.
You've created another short circuit. The simulator seems to be doing something to resolve the conflict.
pinkoryx
Joined Dec 11, 2017
47
The thing is I wasn't taught how to do this before, i'm just figuring things out as I go
Hmm... so I wasn't supposed to do that?
dl324
Joined Mar 30, 2015
18,446
I find that difficult to believe. No one is born knowing how to do this.
No. The simulator shouldn't let a gate pull the positive supply low, so the counter should always be enabled.
pinkoryx
Joined Dec 11, 2017
47
I find that difficult to believe. No one is born knowing how to do this..
Unfortunately, it is what it is. I wasn't even taught how to do any of this theoretically as a freshman or at least at the beginning of this semester
but hey, it works!! I'm so happy! Now I just need to figure out how to make it (the 0-5 counter) hold 5 before resetting to zero (let's hope my instructor doesn't make it mandatory to use a D flipflop because the only D flipflops I know are dolce and gabbana flip flops)
dl324
Joined Mar 30, 2015
18,446
I suggest you get clarification before proceeding.
Normally ripple counters are taught first so you'll be better able to recognize the benefits of synchronous designs.
Close only counts in horseshoes and hand grenades...
dl324
Joined Mar 30, 2015
18,446
I have just been informed as long as my circuit is working just fine, i don’t have to use a flip flop
Did you ask if it was supposed to be a ripple counter (vs. synchronous)?
The logic for a ripple counter will be simpler than synchronous because those counters don't have a carry out signal to facilitate chaining synchronously.
Personally, I think you should go back to the design that was counting erradically, figure out what was wrong, and then connect the two counters.
In any case, you should get into the habit of posting schematics (preferrably of the well drawn variety) whenever you're discussing circuits.
The "^" connection you're referring is the clock input. Normally it's placed on the left side of the symbol and the ">" character is used.
