how can i change 0-3.6V to 1.5 to 2.4V?`
ashokraj
Joined Feb 1, 2018
151
I am looking for a way to change 0-3.6V to 1.5V to 2.4V. are there any possible options? I only have a +ve rail of 2.4V on my board and no negative rail?
Alec_t
Joined Sep 17, 2013
15,171
Do you simply want to measure the 0-3.6V and convert the measured value to something in the range 1.5-2.4V; or do you want the converted voltage to power something?
schmitt trigger
Joined Jul 12, 2010
2,299
This can be resolved by inspection and superposition, applying resistor equations as shown.
As you have 3 variables and only 2 equations, a common method is to assign a value to one of the variables, let’s say make R2 = 10k, and solve for the rest
I will allow you the pleasure to algebraically solve the equations yourself.
38,952
Here's an easy way to solve for the resistor values that avoids simultaneous equations calculations.
Start with an arbitrary resistor value for R5.
Solve for the value of R1 when Vin = 3.6V that gives Vout = 2.4V
Since Vout equals the supply voltage, R3 can be ignored, as there is no current through it.
Using the parallel value of R5 with the calculated value for R1, calculate the value for R3 that gives Vout =1.5V for Vin = 0V
Sim below for the calculated values (left as an exercise for the reader :)).
MrAl
Joined Jun 17, 2014
13,923
Didnt we have this problem already? Maybe on a different website.
There is something unique about this exact particular problem too and that is that the following relationship holds true (using labels in that drawing):
R5=R1*R3
I think that is unique. That makes me wonder where this problem came from originally (input and output voltage ranges).
MrAl
Joined Jun 17, 2014
13,923
So you think it's more than just a coincidence?
Yes, that's what I was thinking, and it would make it very easy for an instructor to figure out if the student got it right or not, almost by a quick glance.
I can't prove that of course, unless the student comes forward with that information.
It also makes me think there could be a completely different approach to the solution. In that sense it could be just a coincidence, but then again the voltages seem so random, yet they can't be too random.
Maybe we will find out in the future.
