How an I/O device, signals the microprocessor that it needs/claims service?
Papabravo
Joined Feb 24, 2006
22,111
The two ways I know about are referred to as 'level' or 'edge'.
With the 'level' method, the I/O device changes the 'level' of a signal from 'high' to 'low' or 'low' to 'high'. You can use either 'high' or 'low' to mean "I need service", but within a given system you should adopt a consistent convention. The I/O device keeps this signal in the "I need service" state until the microprocessor comes along, provides the service and tells the I/O device to 'clear' or 'release the "I need service" signal. The microprocessor should verify that the I/O device performs this operation or it might conclude later that the device still needs service.
With the 'edge' method, the I/O device creates an 'edge' from 'low' to 'high', or 'high' to 'low'. The edge is normally captured by a flip-flop and converted to a 'level' and things proceed as above. At some point the edge capturing flip-flop needs to be RESET so it can capture the next edge.
That's about all there is to it.
WBahn
Joined Mar 31, 2012
33,155
Think about how you know when to put the dog out. You can occasionally look at the dog and see if they appear to need to go out, or the dog can take action to get your attention when they need to go out. The same thing applies for I/O devices.
Natanael Agustinus
Joined Mar 2, 2017
Thanks for your time, I'm looking it up, and found it on Wikipedia, "Types of Interrupts"
So that's kinda related on why do you need software to disable interrupts?.
What does that have to do with signalling?
Actually I got this from my friend, we had the same class, and I'm really confused on this topics, my lecturer only gave me this attachment as a clue.
Papabravo
Joined Feb 24, 2006
22,111
As an overall picture of processor architecture it has some probitive value, but in this specific case it is woefully short on details. To gain a deeper understanding you should continue asking questions like the original one you asked and continue asking them until the "Ahhh..Ha" LED goes off in your consciousness. As an alternative I highly recommend the detailed study of processor datasheets, especially those with pictures and diagrams. I recommend the company, Microchip, for their attention to detail. If there is a particular part you are studying, you can provide a link to a datasheet and we can play "stump the chump". There is no question about the operation of any microprocessor that I cannot eventually find the answer to.
Natanael Agustinus
Joined Mar 2, 2017
Thank you very much, you are a really helpful and nice person.
