how a RF connector being connected onto complex RF PCB
ZCochran98
Joined Jul 24, 2018
356
We use these at work. Summary: the launch pin sits on the trace (tapered up or down to the pin width), while you need to have a sizeable ground pad on either side of the trace that contain GND vias to layer 2, while also having mounting holes that go top to bottom. Backside of the board should have a GND plane that connects up to the RF GND by some vias as well where the connector sits. It'd end up looking (roughly) like this on top:
And this on bottom:
That inner rectangle is the RF GND (bigger than the connector), while the metal separated from it is the DC GND (if you are keeping DC and RF GNDs separated - otherwise, you don't need the gap). Layer 2 then is just a full plane over the entire board for RF GND.
The taper isn't necessary, but it can help with the transition from coax to microstrip.
Don't forget to keep this area free of soldermask.
yef smith
Joined Aug 2, 2020
1,486
Hello , from the photo below i see that i need Guard VIA surrounding the trace and 2 mounting holes.
both VIA and mounting holes are going thew the whole PCB.
how does the connector know to connect to the inner middle RF GND layer?
Thanks.
ZCochran98
Joined Jul 24, 2018
356
The backside RF GND plane is connected to the topside RF GND plane and the layer 2 RF GND plane by the vias. The connector is a clamp-on, so the top half of the "clamp" makes contact with the top RF GND, the bottom half of the "clamp" makes contact with the bottom RF GND, and the vias assert that there is an electrical connection from both to the layer 2 RF GND.
yef smith
Joined Aug 2, 2020
1,486
Hello, i am having trouble to imaginge your words.
Could you please draw roughly how the conector clamps on the PCB shown below?
Thanks.
ZCochran98
Joined Jul 24, 2018
356
Crudely drawn, it looks a bit like this. The next picture kind of illustrates what it looks like on a board:
The next pictures show a side view of a similar connector (not Southwest Microwave-branded, but connects nearly identically):
Hope this clears things up!
Thanks.
Looks like a stripline to me. That seems to be a problem with your selected edge clamp connector. :rolleyes:
https://store-68dp4b.mybigcommerce.com/content/Technical_Articles/SMI-End-Launch-Connectors.pdf
https://resources.altium.com/p/stri...-differences-and-their-pcb-routing-guidelines
