How A 25 Watt Heater Raised The Temperature More Than 15 Degrees.
t_glover
Joined Mar 16, 2021
57
Its cold right now in Northern Canada. My office tinkering room is a corner room so it looses a bit more heat than others. It seems like every time the furnace blower kicks in this little creature spreads herself out on the heat vent blocking most of the air flow.
My solution a 25 watt heating pad in her bed. Problem solved.
dl324
Joined Mar 30, 2015
18,453
Our cats like heat vents too. They lay on them with the AC is on too.
If you get one of these, her own body heat will be retained to keep her warm.
Or get another cat to keep her warm.
