how 7483 adder work?
Status
Not open for further replies.
embedded29
Joined Apr 8, 2017
72
How the chip 7483 chip work?
i dont understand how it circuit is made using gates??
and how gates are build in chip??
Papabravo
Joined Feb 24, 2006
22,111
Start by googling "half-adder". It is a purely combinatorial circuit with two inputs, two outputs, and no memory. Once you understand this simple circuit, you con proceed to the slightly more complicated "full adder". This circuit is also combinatorial; it has 3 inputs and two outputs, and it can be cascaded to handle longer word lengths. From this you can see the deleterious effects of carry propagation time, which will lead you to the "carry look-ahead adder" and the "propagate-kill" circuit.
Papabravo
Joined Feb 24, 2006
22,111
ok, how does computer add in any format like decimal etc large number.
There are two ways.
  1. Build an adder that works directly on the format of interest.
  2. Convert all formats to a standard form, do the addition, convert the standard form back to the desired format.
dl324
Joined Mar 30, 2015
18,467
Computers store numbers in binary format.
Below are the truth table and Kmaps for a 2 bit half adder:
S = Sum, C = Carry
A full adder would have Carry In as a signal.
Status
