hotmelt glue for PCB
pager48
Joined Nov 25, 2018
161
Are hot melt glue sticks corrosive or are there electronics grade hot melt glue sticks available?
wayneh
Joined Sep 9, 2010
18,104
Are hot melt glue sticks corrosive PCBs or are there electronics grade hot melt glue sticks available?
I wouldn't hesitate to use my plain, generic hot melt glue on a PCB. But I'm not sending a man to the moon with my PCB. I really don't think there's an issue but perhaps we'll both learn differently when someone else chimes in.
Ian Rogers
Joined Dec 12, 2012
1,136
Ooh! I'll have a couple of warranty repairs if this be the case.... I've been using it for years.. Bog standard glue.
NOTE!! Don't use it on the circuit tracks, or if you do be careful.. As it cools it shrinks and pulls the tracks with it...
Ford Prefect
Joined Jun 14, 2010
245
I have always wondered but have never asked or tried it, if hot melt glue is a good preservative for circuit boards against dust and contamination also possibly not waterproof but splashproof or condensation against water or other fluids.
DickCappels
Joined Aug 21, 2008
10,661
In 40 years of putting carpentry grade hot melt glued on wiring and circuit boards I have not noticed signs of corrosion.
It can be useful in damping vibration, thermally coupling components to one-another and insulating against the elements.
Careful, an LED assembly that I insulated with hot melt glue saw the glue melt during use. Its not right for everything.
DickCappels
Joined Aug 21, 2008
10,661
It is impervious to water but don't know whether you can count on it to make a water tight seal. It may require an as-yet unidentified primer.
It may be better than RTV but probably not in applications in which flexing or staying attached with extreme variations in temperature. You may have noticed that there are various types of hot melt glue that are readily available, and then there is the hard white stuff used to hold heavy parts onto commercial PC boards which I have not seen in hardware stores.
SamR
Joined Mar 19, 2019
5,491
Application will be harder than painting on conformal coating. And always remember any warm device will melt/soften it.
Ford Prefect
Joined Jun 14, 2010
245
I wonder if clear acrylic spray lacquer in an aerosol can would work to protect a circuit board.
Obviously you would have cover up any delicate or moving components (presets etc.) beforehand.
Has anyone tried spray lacquer?
jpanhalt
Joined Jan 18, 2008
11,087
That is basically what the conformal coating I bought from MG Chemicals years ago is. Of course, there are other versions. In answer to whether it works, yes -- at least in a relatively kind climate like Ohio's.
