Notice that Q1 did NOT ask for the voltage at A, it asked for the voltage at A relative to the voltage at C. This is a very important distinction.Thanks for the reply. But Im not sure how to answer part B to your question. I get your point across the battery, so A would be 5V correct? I need some more help with the B
I think part of the problem is that you are making a common mistake about what "voltage" means.
A voltage is ALWAYS a DIFFERENCE between potential energies. So when we say that the voltage AT a point is 12V, that ONLY makes sense if we have an agreed upon reference point AND it is understood that what we are really saying is that the voltage at that point is 12V greater than the voltage at our reference point.
This is something we do all the time in real life. When we talk about a building being 300 ft tall, we are talking about the difference in height between the top of the building and the ground upon which it sits. While if we talk about a mountain being 14,000 ft tall, we are talking about the difference in height between the top of the mountain and mean sea level. If we mean anything else, say the height of a mountain relative to the surrounding plains, then we have to be more explicit.
In circuits, we pretty much always need to be more explicit. So, by convention, we choose one node in the circuit as our reference point and declare that node to be 0V. This is called the "common" node (often called "ground", though this is technically something different) and we place a special symbol (a "common" or a "ground" symbol) there to indicate this choice.
Now we can talk about the voltages at the other nodes because we have an agreed upon reference.
So the answer to Q1 is 5V, but the voltage at Node A is only 5V if we happen to choose Node C as the reference node (or, if it should turn out that Node C just ends up happening to be equal to 0V relative to whatever reference point we choose).
We could choose Node A as our reference point, in which case the voltage at node A would be (by definition) 0V and the voltage at node C would be -5V.
When all else fails, fall back on the definitions.
Putting a battery of voltage Vbatt between nodes X and Y (positive terminal on X) means that
Vx - Vy = Vbatt
Similarly, connecting a resistor between nodes X and Y means that
Vx - Vy = Ixy * R
where Ixy is the current flowing from X to Y through R.
See if that helps you at all.
