Holden/GM Fuse panel connectors ID
SimpleJoe
Joined Mar 22, 2016
38
I am trying to add power for a dash camera and a few other electronics inside the cab of my 2011 Holden Colorado which I assume uses similar connectors to the rest of GM's products.
I would like to avoid tapping into the cigarette lighter or any other circuit and instead use some of the spare fuse spots in the cabins fuse panel but I can't seem to find any connectors that look similar to what I am after.
It is sized between a regular blade connector (6.3mm and 5.Xmm) and has a clip in locking tab on the connector itself, any pointers in the right direction would be a great help.
shortbus
Joined Sep 30, 2009
10,050
Stuff like that is usually hard to find. Some times a dealership will stock them, but when I need something like that it's time to go to the auto recycling yard and get a connector with as much wire on it as possible. Then you would just splice the wire to your new wire for the camera. Use heat shrink tube on the splice.
