Hobbyist looking for some help! --LEDs on gameboard
Shadespire
Joined Jul 18, 2020
6
Hello!
New to all of this. VERY new. I'm very overwhelmed with searching with no base knowledge. All I have is this idea!
I really want to incorporate LEDs in to a game board I'm planning to build.
I'm trying to create a single power source with 16 on/off switches, each of which controls a string of 12 LED lights.
Is it possible to connect with someone to put together a map and parts list? I have a local shop that would have all the parts needed and I would be comfortable building it.
Thank you all in advance for your help!
Shadespire
Joined Jul 18, 2020
6
That's it - the whole set up is to illuminate a game board with one of those 16 switches representing different starting positions. The photo below is one of the board options to choose from - so each of those white skulls would be an LED
So really, only one of those 16 lines needs to be illuminated at a time
KeithWalker
Joined Jul 10, 2017
3,614
This is a very simple project but a little more information is needed before we can put values on power sources and current limiting resistors.
What type and colour of LEDs are you planning on using? Different coloured LEDs have different forward voltages and different types of LEDs require different currents..
What do you have available for a power source, battery or mains?
Keith
Shadespire
Joined Jul 18, 2020
6
This community is great, Thank you for the replies and willingness to try to understand the ramblings of someone so uninformed.
Ideally battery supplied.
There are 16 different board options so each LED string would illuminate the markers on one specific board.
https://www.underworldsdb.com/boards.php
At a minimum, each has 7 starting points which would be in a soft white LED. Then each board would have the additoinal (BW - Bright White, R-Red)
1 - 0
2 - 2 BW, 1 R
3 - 3 BW
4 - 1 R
5 - 1 BW 3R
6 - 2 BW 1R
7 - 0
8 - 2 BW 2R
9 - 3 BW
10 - 3R
11 - 0
12 - 3 BW
13 - 0
14 - 3 BW
15 - 3R
16 - 2BW 1R
Shadespire
Joined Jul 18, 2020
6
Welcome to AAC!
How are the strings of LEDs to be selected? Manually closing switches, some fixed pattern, a random pattern, etc?
I have so many questions...
If i could have something like a slider switch would be ideal - like position 1-16, otherwise individual on/off switches are fine.
dl324
Joined Mar 30, 2015
18,446
  1. What event causes a certain string of LEDs to need to be turned on?
  2. How long do the strings stay on?
  3. Is there a single pattern? Or is it random?
  4. What is the battery voltage?
  5. What is the forward voltage of the LEDs?
  6. 0 means no LEDs in a string?
  7. In the original post, you said each switch controls a string of 16 LEDs. Post 6 doesn't show that.
  8. What is the maximum ambient brightness where the game will be played (e.g. ever outdoors in bright light)?
  9. Would you ever want to control brightness?
  10. The LEDs are going to be mounted on/in a game board? Will all of the LEDs in a string be next to each other? Or spread out?
It would be helpful if you tried to anticipate our questions so this will be less like a game of 20 questions.
Shadespire
Joined Jul 18, 2020
6
THANK YOU!!!!
  1. What event causes a certain string of LEDs to need to be turned on? - user control, when a board is selected, it will then be switched on and illuminated
  2. How long do the strings stay on? 2-3 hours
  3. Is there a single pattern? Or is it random? - single pattern -each string represents one board so would be full user control
  4. What is the battery voltage? - no clue
  5. What is the forward voltage of the LEDs? - also, no clue
  6. 0 means no LEDs in a string? - means no extra, each string has a minimum of 7
  7. In the original post, you said each switch controls a string of 16 LEDs. Post 6 doesn't show that. - the on off function of each string can be flexible pending ease of design and build - just need a way to control each individual string independently (but no more than 1 would ever need to be on at a time)
  8. What is the maximum ambient brightness where the game will be played (e.g. ever outdoors in bright light)? - in doors, they're just markers so dont need to be too bright
  9. Would you ever want to control brightness? - no, uneventful to the game and seems unnecessarily complicated for no value add. .
  10. The LEDs are going to be mounted on/in a game board? Will all of the LEDs in a string be next to each other? Or spread out? they will be mounted to a board, the board itself will have between 2-4 inches between LEDs
dl324
Joined Mar 30, 2015
18,446
How large are the boards? How much area will they cover? Does each player control any of the LEDs? Or is there a single player with control?
Do you want to operate with batteries or an AC adapter?
Can the boards be illuminated at random?
What is your preference? This will determine how many LEDs can be in series.
We can use typical voltages initially.
Sorry, missed that.
That simplifies drive circuitry.
Can you show us a mock up of how the boards will be placed and how you want the LEDs placed on them (including color)?
Do you have a preference for LED size or shape?
Shadespire
Joined Jul 18, 2020
6
- Board size is 27 cm x 40 cm
- Each player selects their 'map' (pic below) then illuminates the board - the example here would be the basic 7 minimum needed (as shown by the skull markers) and then the 3 with edge in bold lines would show the bright white LEDs - the light does not need to form a border, just an indicator on the hex itself.
Battery operated is ideal for transport (play at friends, local hobby shops)
The boards would never be illuminated at random (if need be, we could roll a 16 sided die)
I dont understand enough (sorry) to have a voltage preference, typical voltages seem ideal to simplify and minimize cost
LED size is not crucital - (3.2/5mm??), they're just indicators, as long as they have a flat top to integrate with the build of board itself and keep a level playing surface.
Again, a million thank yous!
Bernard
Joined Aug 7, 2008
5,784
Might consider using 6 rechargeable Ni-M-H batteries in series for about 7V. LEDs in combination of 2 in series & singles. With low current, 5 mA, then might be 17- 2s & 7 singles; high current,15 mA, 12- 2s & 12 singles. Next choice would be 12V. I started to see which had lowest power demand but seems there is not enough difference to care. Still not sure what the game is all about.
