Hi all and everyone is OK I hope.
I have a problem with my Chinese mini MP3 player. Power supply is 220 v in and 24 v out switch mode type. There are one subwoofer amplifier ( Chinese type ) and hand made LA4270 stereo amplifier powered by this power supply.
Both amplifiers line in ( L & R ) are connected parallel then MP3 player line out ( L & R ) are connected to amplifiers line in.
To power up the MP3 player I made a voltage regulator using by 7809 which is powered with 24 v.
When MP3 player is off the amplifiers give no hmmm or buzzzz.Very pure and smooth. Works perfect.
The story begins when I power the player on. Even if there is no signal on the line out a hmmmm sound starts.
I powered the MP3 player by an external battery and it is OK. Pure stand by sound. So I decided that the problem is related with 7809 voltage out.
MP3 player has an embedded 78M05 on it. It wakes up minimum 6 volts so I decided to use 7809. My regulator had a 100 uF / 25 in and 47 nF out in the beginning. Later on I put 470 uF to V-in and 2 x 10.000 uF parallel to V-out. The hmmm sound has been decreased almost 80 % but you now I still hear the 20 % when the music ends between the songs.
Yes maybe there is a way to remove it 100 % but I am not an engineer and just a hobby maker. Circuits are mounted in a metal box and well grounded to the chassis.
Your suggestions will be highly appreciated for me. Thanks in advance.
