Does anyone know of a voltage/current sensor IC that will work on voltages up to 600v?
Please provide more information -- What exactly do you wish to do?Does anyone know of a voltage/current sensor IC that will work on voltages up to 600v?
I need to accurately measure DC voltage and current in circuits with voltage ranges between -600v to +600v where the information will be fed to a microcontoller.Please provide more information -- What exactly do you wish to do?
It wouldn't seem that you need a special sensor? -- You need merely scale and 'offset' the level such that the anticipated extremes fall within range of the ADC input...I need to accurately measure DC voltage and current in circuits with voltage ranges between -600v to +600v where the information will be fed to a microcontoller.
I'm assuming you mean use a resistor divider on the input of the sensor? That would be great but I would need highly matched resistors and I can't seem to find any sensors that will measure negative voltage.It wouldn't seem that you need a special sensor? -- You need merely scale and 'offset' the level such that the anticipated extremes fall within range of the ADC input...
I don't get it, aren't those meant for measuring AC on DC lines? How am I supposed to measure a 600v line with an opto anyway?Or consider isolation amplifiers
http://www.mouser.com/Semiconductors/Amplifier-ICs/Isolation-Amplifiers/_/N-4fs2k
Or if you need to design something yourself, consider using optical couplers. You will probably have to come up with an floating power supply to power the sensor side of the circuit.
I'm feeding the measured voltage and current into a microcontroller so I can use it as a feedback mechanism for a high voltage digital potentiometer.What do you want to do with the sensed voltage and current
Correct.I'm assuming you mean use a resistor divider on the input of the sensor?
Standard value resistors are available to (at least) 0.5% tolerance.That would be great but I would need highly matched resistors
Hence the requirement of 'offsetting' the scaled EMF such that the lowest anticipated excursion corresponds to a non-negative value (post translation)...I can't seem to find any sensors that will measure negative voltage.
