High Voltage H-Bridge for DC Motor
MaxHeadRoom
Joined Jul 18, 2013
30,881
Both sides are identical , not sure why it does not work? sounds like the two Mosfets on one side are on?
Leave motor disconnected and see if the high current still exists, IOW test where the high current is sourced.
nikos_asi
Joined Feb 12, 2025
13
Max, maybe this happens but I decided to make the board again to test it.
I will come back with fresh news and I hope the problem to be fixed.
28,576
Actually, in post #27, I should have stated " be sure that the GATE CHARGE, and voltage, are completely removed when the mosfet is supposed to be switched off. My apology for the omission.
nikos_asi
Joined Feb 12, 2025
13
I received the new parts, I made a new board and I took some measurements on gate drivers (IR2110) before to install the mosfets.
When the system is power on I took:
IR2110 (driver1)IR2110 (driver 2)
Pin 7 11.26VPin 7 11.26V
Pin 1 0VPin 1 0V
When the code runs in CW direction
IR2110 (driver1)
IR2110 (driver 2)
Pin 1 0VPin 1 10.63V
Pin 10 4.96VPin 10 0V
Pin 12 0VPin 12 4.96V
When the code runs in CCW direction
Pin 1 10.63VPin 1 0V
Pin 10 0VPin 10 4.96V
Pin 12 4.96VPin 12 0V
What I noticed it's that in both CW and CCW directions the HO Pin 7 on both IR2110 remains active and the only change is on the LO Pin 1 when I change the direction.
Is it normal? With this way it works the H-Bridge?
Thank you very much for your help, I really appreciate it.
Nikos
