Use 500V 10A solid state relays RM1D500D10:Hello, how can I switch both the positive and ground lines of 310 volts 5 Amps using mosfet? frequency 2hz=500mS SWİCH LOAD
I don't want to use role
Well, then do it yourself, maybe it will cheaper:too much
too muchUse 500V 10A solid state relays RM1D500D10:
https://www.mouser.com/ProductDetail/Carlo-Gavazzi/RM1D500D10?qs=DPoM0jnrROWNAra8g2irog==
Try to ask LTspice ( https://www.analog.com/en/design-center/design-tools-and-calculators/ltspice-simulator.html ).What is my missing here and my mistake?
No.Do I need to add a snubber to the circuit?
Do I need to add a snubber to the circuit?Try to ask LTspice ( https://www.analog.com/en/design-center/design-tools-and-calculators/ltspice-simulator.html ).
It will answer most of your questions:
