High-voltage distribution line cable insulation question
MisterBill2
Joined Jan 23, 2018
28,112
When I worked at a place in WARREN, Michigan, it had 3-phase 120, with a higher voltage between the three legs. The three phases were adequate to power the 3-phase motors on the shop machines.
wraujr
Joined Jun 28, 2022
264
When people say "120V 3-phase," they are almost always referring to a 208Y/120V 3-phase Wye system, which is extremely common in US commercial, apartment, and light industrial buildings.
MisterBill2
Joined Jan 23, 2018
28,112
wraujr called it exactly right!! And in the area where that shop was located the voltages were not quite equal. The 3-phase motors ran OK, but my recollection is that for the 120 volt phases , one leg was a bit less.
loveforcircuits
Joined Jan 31, 2026
165
From the outlook of the poles, bushings and cables present in a line, is there any way to tell how many KV the line is? In my country there are lines of 33KV, 11KV, 440V and 220V. But I don't know (or maybe I read at the University and forgot) how to identify which line is carrying how many volts.
In Addition to the information in post#47, consider also what the various different voltages are connected to: 120, 220, and 440 volt lines would connect directly to a power user of some kind, mostly thru some sort of meter used to measure power used. The higher voltage lines will include both step-down transformers and switch-gear of some sort. At transformer connections the higher voltage lines always connect to the taller insulators of the transformers, often thru a fuse or a switch of some sort.
