I tried to simulate a circuit using your scheme, but mine fails to work.I have a pulsation on the output on the diagram. Peak-to-peak is about 0.1 mV (pulsation at the input is 20 V), f, which means that the ripple suppression factor is 200,000. This is the result of using transistors with a built-in channel.
I tried to follow it as close as reasonable, but right now I don't see the problem.
I attached the ltspice file and the libs I'm using (I once had problems with the tl431 models)
Could you please tell me if it works for you? Or what mistake did I make?
Thank you
