High voltage component clearance
PowerElectronicsGuy
Joined Aug 20, 2020
Hello everyone.
Obviously when designing a high voltage PCB, we must make sure that the areas of copper, that have high voltage differences, must have an adequate clearance. However, what about the clearance, for example, between a trace on the top layer and a component on the top layer. For example, lets say I have a trace running in between the two pads of a big high voltage TH capacitor. Even if the trace is sufficiently distant from the pads of the capacitor, should I be worried about the clearance betwwen the trace and the actual body of the capacitor? Also lets say for example, that I have two or more TH resistors in parallel, like in the picture (R25, R26, R27). They all connect 300V (a high voltage) to GND. Should i be worried about the clearance between the resistor bodies? Beacuse the voltage is distributed down each resistor, and probably not evenly so, so there migh be a high voltage difference in between two adjacent resistors that migh cause problems if the two resistors are too close.
TechWise
Joined Aug 24, 2018
151
I would not worry about this as there will be a solder resist coating in place followed by an air gap. I have a PCB with upwards of 400V on it passing under large polypropylene film capacitors.
ronsimpson
Joined Oct 7, 2019
4,888
It may be over kill but; I often use silk screen under HV parts. (white filled rectangle) It adds insulation and helps me remember "HV" here.
