Hi to you all.
I am having this issue which suppose to be easy because it is just resistive attenuator but trust me it did kept me awake at night and kept me busy.
I need to measure a high voltage ( round 1000V ac mainly transient and 600V DC) thus I need an attenuator factor of 25. I am using a T type attenuator with a series resistance of 9M ohms and a shunt resistance of 801K. The input or the output impedance is 10M. This circuit is a conditioning circuit for my measurement circuit which has an input resistance of 10M.
I am having two issue:
1- The attenuation for DC voltage differ from AC voltage ( the difference start even at frequency of 10Hz).
2- The attenuation bandwidth is low ( less than 10Khz at -3db).
I checked the internet for attenuation circuit and the popular one are T type and PI type but most of the explanation is done for low input impedance and I guess for also a low voltage.
Do these T type or PI type attenuator also work for high voltage with high impedance ( the high impedance feature is needed because the attenuator will be connected to a safety critical circuit)?
I need a bandwidth of 30Khz at -3dB which suppose to be easy to achieve with a passive attenuator.
Does anyone have a solution or this problem?
Thank you in advance.
