- Joined Jan 23, 2018
- 27,511
Power those lights with ten volts and they will still provide adequate lighting, but last much longer and not run nearly so hot. And use those connectors at each end of the tube. The mating parts can be turned from stainless steel, one of the softer alloys. You may even find SS tube in the right diameter. And one at each end of the tube will make it simple, if the tube penetrates thru the sides of the lid. Then it can just slide out easily and the two connectors can hold it in place during use. An added benefit is that the externl wiring will not need to be inside the lid where it is much hotter.
