High Side Gate Driver for Power MOSFET
combover1961
Joined May 20, 2024
22
Many IR2117 past threads, yet none helped me resolve the problem ... thus this new thread )
Built the attached data-sheet schematic (I determined values).
Poor, intermittent operation ... sometimes nothing ... sometimes fan briefly starts then stops.
Using +12 Vdc for all inputs.
Sure seems like a straight forward circuit ... yet I am perplexed a bit )
Anyone that might have something to chime in is welcome ... and much appreciated.
The goal is to simply turn ON & OFF a power MOSFET (+12, 24, 48 Vdc), for a fan motor load.
combover1961
Joined May 20, 2024
22
okay ... so my post was premature ... I now believe that I simply need a P-channel MOSFET.
This N-channel MOSFET requires ~ 3-5 V + the supply (12V) to turn ON.
This is not realistic for my final application ... so I will change to P-channel and complete bench tests.
ronsimpson
Joined Oct 7, 2019
4,833
I have used the IR2117 many times and it works. The duty cycle cannot go to 100% on. It must be off for a time to recharge the capacitor.
P-FET is an option.
I would use a N-FET and switch the ground side of the fan. The Gate Driver is very simple this way.
LowQCab
Joined Nov 6, 2012
5,102
If switching the Ground-side is not practical for your application,
use a Photo-Voltaic-Gate-Driver as shown below.
This works with High-Side, or Low-Side, Control equally well, no P-Channel required.
But, the Photo-Voltaic-type-Gate-Drivers can not be used for "High-Speed-Switching"
as they are somewhat "slow", ( several Milli-Seconds, depending upon the specs of the FET used ).
DC Switch 1 .png.
combover1961
Joined May 20, 2024
22
View attachment 324158.
Hey there .. really appreciate the feedback ... thank you kindly )
So I do not anticipate a problem with this new circuit.
The HO value will always be 0 or +12 Vdc, with a power supply of +12, 24 or even 48 V.
The VGS will always be negative as required for the MOSFET to turn ON with a +12 Vdc HO, and turn OFF with a 0 Vdc HO.
My load will connect between the MOSFET drain and ground, which is ideal for my application.
I will bench test when parts arrive, my only real concern is the V drop of the MOSFET (0.1 Ohm x 20 A = 2 V).
I wish that I could eliminate this V drop.
LowQCab
Joined Nov 6, 2012
5,102
Just select a more appropriately rated MOSFET, problem solved.
Don't get stuck on the one solution that You think You finally understand.
There's more than one way to skin a cat.
I think that there is nothing easier than driving a single LED, as I previously suggested.
combover1961
Joined May 20, 2024
22
P-FET is an option.
Thank you kindly ... I am not sure that I 100% agree though ... I'll bench test Tuesday and share the results. The 10k resistor to ground is simply to give a place for any in-rush currents to go after the MOSFET is switched OFF. Trying to protect the IR2117.
combover1961
Joined May 20, 2024
22
Thank you kindly LowQCab ... yeah .... as it turns out, there is a much lower Rds MOSFET 0.01 vs 0.1 Ohm. It is a $6 premium x4, but since my client keeps telling me that he wants all the premium features, well, easy decision )
combover1961
Joined May 20, 2024
22
~20-Amps DC for a Fan(s) !!!! that's serious Power.
Why 3-different Voltages ?
The application is typically just +12 Vdc.
But sometimes, the same application requires +24 or +48 Vdc.
I doubt they will ever see the 20 Amps, just a required feature.
combover1961
Joined May 20, 2024
22
The Gate Driver, when outputting a 0V signal is shorting Gate to Drain.
The Gate Driver, when outputting a 11V signal is putting a 11-volt battery from Gate to Drain.
Neither of these conditions are good.
Thank you kindly for this input ... I am completing the bench test to verify solid functionality.
Gotta start with what I believe is correct, but I am by no means the MOSFET expert.
ronsimpson
Joined Oct 7, 2019
4,833
If you are going to do this:
Using a P-MOSFET, the Gate on voltage us below the +12/24/48V supply. So with a 48V supply, a Gate voltage of 40 will turn on the P=FET. A Gate voltage of 48 will turn it off. (note you must drive the Gate-to-Source not the Gate to Drain)
I connected the Vb supply to the (+12/24/48V) supply. Now when IN =high, HO=Vb and the Gate-Source voltage = 0V, MOSFET=off. When IN=low, HO=Vs which is (+12/24/48V supply)-11 volts.
That works BUT: C 10uF on Vb-Vs will never charge up. There will never be a charge on the cap so HO cannot function. In both circuits (using the P-mosfet) the IR2117 will never get a supply voltage stored on the capacitor. Will not work.
If you have to have a topside driver, then use post #11, using a P-FET.
or use post #4 if you are just turning on/off and are not using a PWM like 100khz. (slow turn on/off)
or use a bottom side driver.
combover1961
Joined May 20, 2024
22
WOW, thank you kindly for all the details. I learn best by bench work ... so I will see all of this firsthand, very soon )
combover1961
Joined May 20, 2024
22
Disappointed in the bench tests that confirmed your suggestions. Well I guess I have to wait another day to solve this with the new parts that are on order ) I'll try both of these suggestions .. FDA215 & ITC7001. Many thanks for the extremely helpful contributions )
combover1961
Joined May 20, 2024
22
My approach failed ... so I'm trying your suggestions tomorrow ) Many thanks )
