schmitt trigger
- Joined Jul 12, 2010
- 2,244
It’s actually a Down Under opamp. Its CMR extends about 200 mV below its negative supply rail. (From my faulty memory).
Okay.It’s actually a Down Under opamp.
Works as long as you don't mind having to adjust the zero output with a pot, and the lower common-mode rejection to changes in the supply voltage.This is an easy way to make any Op-Amp work ...........
If it initially requires a pot, what is the reason to go to the significant effort of replacing it with fixed resistors after offset adjustment (with the limited values of fixed resistors likely leaving some residual offset)?The Trim-Pots are only for Bench-Setup,
to keep the Input, and Output, Voltages comfortably within the capabilities of the cheap-Op-Amp,
then they may be permanently replaced with the appropriate Resistors.
.it may also need in-field calibration from time to time.
btw if gal is to measure current in high side, why not used products designed just for that? there is bunch of amplifiers for this purpose (INA, INB...)
I must have "skipped-over" that also.You must have skipped-over the part where the TS stated that
super-cheap generic-Op-Amps will be used,
