High current buck converter to shutdown when led temperature reaches to its limit.
imraneesa
Joined Dec 18, 2014
227
Dear all,
I want to know how to make constant current buck converter shutdown when the led temperature reaches to its limit. I want buck converter to shutdown when the led temperature rises to exactly 70 degrees. i want to do this project. current i need for the led is 3A.
Thank you,
Best Regards,
Imran Mohammad
38,951
You use the NTC thermistor as part of a voltage divider with another resistor to generate a voltage that varies with the LED temperature.
That voltage trips a comparator (e.g. LM339) at the desired voltage (temperature) which shuts off the converter.
Dodgydave
Joined Jun 22, 2012
11,395
I would use a Lm35 temperature sensor with a comparator chip, and use that with a mosfet to shutdown the buck converter, ideally which buck chip are you using?
imraneesa
Joined Dec 18, 2014
227
Dear Sir,
I want to use MAX16820 as i have been using it for led driver before. if i have to use lm35 do i need to attach it to the heat sink of the led for it to sense the temperature. i want this project as led driver to be able to use for the hand held flashlight. Thank you,
Best Regards,
Imran Mohammad
QUOTE="Dodgydave, post: 1154823, member: 170203"]I would use a Lm35 temperature sensor with a comparator chip, and use that with a mosfet to shutdown the buck converter, ideally which buck chip are you using?[/QUOTE]
