Hi to all. I want 3 digit display.
I searched for it with no success. Is that from a specific device? If so, I don't think you're gonna get the same one. Generic 4-digit modules are more common to find. If you want strictly a 3 digit module for a specific application, you would want to build your own one with a bare 3 digit 7 segment display.
As said above, try looking at Ebay.
bertus
Joined Apr 5, 2008
22,986
What should the display do?
Count something?
Measure voltage or current?
Or do you need a bare display?
Bertus
Burbure
Joined Aug 1, 2018
9
Thanks all for support. Actually I have repaired welding machine. Ecoweld. 315amps rated. It ic not getting. I have order to Ali express. But it seems the dispatch was within 8 to 10 days.
Till then any one knows the ic as I attached. Its MXD008/ GN058KH008.
Regards
Tonyr1084
Joined Sep 24, 2015
9,744
I have a couple of those laying around at home. Not sure if they're common cathode or common anode, but I salvaged mine out of old tread mills.
On that note: You need to know whether you are looking for common cathode (common negative); or common anode. Not just any 3 digit display will work. Also, there may be some wiring differences from one display type to another. Is there a number on the display you can see and report to us? It would likely be on one of the long sides.
