hi there. i please for thoughts about notebook motherboard repair
disturbed123
Joined Jun 11, 2020
122
There is about one fallen notebook. the fall was not so bad at all.
Have tried :
remove the 2032 and 1 minute power button. the battery is about 3 volts. Reinsert it and with or without notebook battery absolutely no LED indications.
Have measured the voltage after the plug port and it`s good everywhere.
Have reinsert the cable between power board and motherboard and still nothing.
In technics what compont (like resistor diode etc ) is going failed after device falling on earth
Could you give me directions kind from to to fix this situation ?
thanks.
Irving
Joined Jan 30, 2016
5,076
Broken contact
Broken PCB trace
Broken chip internal bond
etc
etc
May or may not be visible, many possibilities
Without schematics and a good knowledge of troubleshooting techniques may be impossible to locate fault(s).
dl324
Joined Mar 30, 2015
18,296
Welcome to AAC!
That's a nearly impossible DIY job. Even if you managed to locate and replace some defective components, you have no way to exercise 100% of the logic to make sure there are no other problems.
With a laptop, you don't even have a way to monitor power on self test (POST).
