New demo!
Prompts controller (OP) to enter master code at power-up. Servo "locks" once code is entered. Both red and green LED's are lit to indicate master code is to be entered. Display changes each digit from a dash to a P to indicate it has received and stored the number entered for that digit. * and # symbols are ignored.
Servo "unlocks" and stays unlocked once correct code is entered.
I need to add a command to unlock the servo at power-up in case it was left in a locked condition for ease of use.
OP may have to tweak servo values in code depending on servo used - not all servos operate at the same angles.
For now, I'd suggest using the flashing LED's you bought earlier to attract passersby - perhaps spell out Crack the Code. While you could buy or build large LED displays and connect these in parallel to the existing digit LED's, I'd recommend doing this for a later fete. This is going to add time, complexity, and cost and I think there is plenty to do right now. I'm just afraid of running out of time to finish the design and having enough time on your end to get this altogether.
Let me know what you think. I'm going to tweak the code a little and polish up the schematic so I can get you a parts list. While the parts are on order, I'll begin working on the PCB layout to make it easy for your friend. If you really want something more than what is shown in the video, please let me know now so I can incorporate it. Once the design is done, it will be difficult to add to after the fact.
