You could punch a specific code into the keypad to get to allow you to change the player's code on the fly. We could light up four LED's, one per correct digit of the four-digit player code, then a fifth and a buzzer/fan to indicate a winner. These four LEDs could either be set to light up as the player pushes the correct button or on a timed sequence (the latter being a little more difficult). Alternately, you could punch in another code to manually eliminate the need for the 1st, 2nd, and 3rd digits (and light up corresponding LED's) as you saw fit depending on how the fete was going. Or use switches only you have access to to eliminate digits 1-3.
Just a thought.
Every time I click on the link, it says the site is down. Don't know if it is really down or has something to do with me being in the U.S. If they carry electronic parts and PICAXE IC's that would work. If they don't carry PICAXE, then I don't think shipping will be much more from the PICAXE supplier to get all the parts from one place. Up to the OP of course. Hopefully the site will be up and I can locate and call out parts.Delivery (shipping) is free from CPC - http://cpc.co.uk and you should be able to get most of the things you require from there.
I referenced a slightly cheaper one, but an OLED display looks quite nice. I don't think that one is much bigger than the keypad. They also carry a 20x4 LCD which would be much bigger.i know i said screen not needed but this seems impressive
http://www.picaxe.com/Hardware/Add-o...l-OLED-Module/
seems quite big.
You can do a number of things. The simplest is using larger LED's like 10mm in place of 5mm. You could also use several LED's instead of one (for each digit) and cluster them to make a shape or simply a large lighted circle.Also how can I make the the effect of the leds bigger
Looks like it might require soldering, but yes, that is it. So, would you like to use this with a red and green LED for each digit, a servo (lock), and a keypad? Do you want a buzzer?this is from Amazon free shipping is it ok
http://www.amazon.co.uk/Adafruit-4-D...c:1401474497
