Hi, can somebody help to change dual gate jfet in transistor
michael1978
Joined Jun 29, 2014
309
Hi, everybody, can somebody help? how to change this 40673, in transistor is that possible, because difficult to find dual jfet and also i undertsand better transist bjt and jfet than dual jfet this is the shematic1.jpg
michael1978
Joined Jun 29, 2014
309
There are quite some dual gate mosfets.
I have used the BF980 and BF981 in the past.
40673
BF980
BF981
BF982
If you really want to change the circuit to a BJT circuit, you could have a look at this post of your other thread:
https://forum.allaboutcircuits.com/...uild-fm-mixer-thnx.152805/page-2#post-1312576
Inject the signal of the oscillator to the emittor of the BJT.
Bertus
Hi Bertus, is this circuits the same like he show me sir Bordodynov, can i use that circuit in place from this circuits with mosfet, i understand beter.
and more question, normal local oscillator must be from 88-108mhz( i mean with tuning), for fm superheterodyne
michael1978
Joined Jun 29, 2014
309
Hello Bertus, i have just this question because now i understand, just local oscillator must 88-108mhz, like i read in internet ? correct
bertus
Joined Apr 5, 2008
23,040
For an IF of 10.7 MHz, the LO must be 10.7 MHz higher or lower than the frequency to be received.
Read the section about the LO on this wiki page:
https://en.wikipedia.org/wiki/Superheterodyne_receiver
The frequency of the local oscillator fLO is set so the desired reception radio frequency fRF mixes to fIF. There are two choices for the local oscillator frequency because the dominant mixer products are at fRF ± fLO. If the local oscillator frequency is less than the desired reception frequency, it is called low-side injection (fIF = fRF − fLO); if the local oscillator is higher, then it is called high-side injection (fIF = fLO − fRF).
Bertus
michael1978
Joined Jun 29, 2014
309
Bertus
Thank you very much Bertus, i understrand, have i nice day...:);)
