Here we go let's make a High-Quality Function Generator
be80be
Joined Jul 5, 2008
2,395
This is the deal I got a nice outdated XR-2206
I'm starting like this Circuit. Anything you see I need to do to make it better.
Next problem I want use a 12 volt wall wart like this.
RichardO
Joined May 4, 2013
2,270
Is your output referenced to the artificial ground? If so then you won't be able to supply much power into your load -- not even a milliamp. :(
Papabravo
Joined Feb 24, 2006
22,111
The XR-2206 is kind of a crappy function generator. There is a good deal of distortion over 20 kHz. in the sine wave. The triangle has rounded and bumpy corners, and lastly the square wave has numerous artifacts, espacially at higher frequencies. I built one of these a long time ago (ca. 1978) and seldom used because it was just a piece of crap.
If you really need one, you should buy one or rent one.
DbLoud120
Joined May 26, 2014
101
XR2206.png XR2206.png Hi be80be, I found this schematic some time ago. Not sure who author is. I was interested enough that I purchased an XR2206 but have yet to test circuit.
Seeing your post makes me want to at least breadboard circuit to see how well it might work. I will post results when I have something to see.
I do have oscilloscope to check waveforms.
be80be
Joined Jul 5, 2008
2,395
I have the parts and a scope I just wanted to start with the best circuit.
The only thing I don't have is a split supply. Was trying to come up with a work around for that I tested what I posted just don't think it will output
The power needed
atferrari
Joined Jan 6, 2004
5,028
AD9834CRU something like that
YES!! YES!! YES!,
I suspect my 10 MHz Siglent función generador is built around one of these.
My experience: the stumbling block is not other than the output filter.
Wait and you will see comments telling it is easy to design. But not for me.
I would like to write the code to program it. Really.
Standisher
Joined Jan 16, 2015
154
There's a short series of videos (by 'Scullcom Hobby Elecronics') on Youtube about his project to build a function generator using the XR-2206, an arduino nano and a 7 segment display. I copied his design almost to the letter, including the enclosure he used (except that I added a Function Counter which he never did get round to adding as originally planned) and it does work quite well, particularly in the audio ranges. I can only get to about 150kHz before the signal becomes quite distorted. My unit does also tend to 'drift' a bit after a while but I don't know if that is a feature of the chip or as a result of my construction :oops:. Anyone interested in playing with this chip may also like to have a look at the Exar XR-2206 Function Generator Databook which can be found in pdf format here . A picture of my completed version of Mr Scully's project is attached.
KL7AJ
Joined Nov 4, 2008
2,229
Excellent! I JUST happened to find one of those chips last week in my ancient parts bin! I understand the chip is no longer in production, but plenty of NOS sources.
It's a wonderful chip.....I don't know WHY so many manufacturers discontinue absolute winners like this.
Nice job. I'm building a local oscillator for a low frequency receiver with this.
